TRIM C290
TRIM C290
TRIM C290 is water-clear, low-foaming, and low-misting, contains no chlorine, phenol, nitrites, copper, triazine, or silicone and is PRTR compliant, with no SARA 313 reportable chemistry. Easily removed from parts for quick cleanup before assembly, painting, or plating operations, TRIM C290 is truly a joy to work with and manage.
Master Fluid Solutions® is proud to announce our new, high-performance metalworking fluid, optimized for the chemical, environmental, and machining requirements of general aluminum parts. Formulated to allow great, nonferrous corrosion prevention on most aluminum alloys, TRIM® C290 provides great results in a wide range of operations with its very low carryoff and long sump life resulting in low operating cost.
TRIM C290 is a high performance, easy to use and maintain metal removal fluid with very high levels of usable lubricity at the point-of-cut. "TRIM C290 is an exciting new addition to our metalworking fluid portfolio in North America," says Justin Geach, Global Director of Marketing. "C290 is a multi-metal, clean running synthetic with excellent corrosion resistance to nonferrous materials, including aluminum. Its high lubricity, low pH formula allows for a wide application range of grinding and machining on ferrous and nonferrous materials, offering customers the benefits of a full synthetic with better machine and material compatibility over traditional synthetics."
This latest addition to our synthetic fluids is available for sale throughout North America
