USB and RJ45 fitted sockets for mechanical engineering and automation
The norelem firm is expanding its range with compact fitted sockets for USB and RJ45 connections to more easily integrate common data interfaces into housings, switchboxes, control panels and other applications. Different connection variants and designs offer flexibility for different installation situations.
The new USB and RJ45 fitted sockets allow for easy access to interfaces integrated in enclosures, switchboxes or control areas. They thus ensure that USB and network connections are available exactly where needed.
For USB connections, customers can choose from various versions with USB-A and USB-C. Depending on the requirements, variants for USB 2.0 or USB 3.0 are available as well. This means that both existing applications and systems with higher data transmission requirements can be equipped with a suitable interface.
The range is complemented by RJ45 fitted sockets for the integration of network connections. They make it possible to provide Ethernet ports in an easily accessible position on the respective housing, control cabinet or control area.
Compact design and effortless integration
The fitted sockets are distinguished by their flat construction and ergonomic design. Boasting an installation diameter of 22.3 mm, they can be easily installed and integrated into different applications to save space.
