VM250IL-5x 5-Axis Vertical Machining Center
Milltronics offers its new VM250IL-5x 5-axis vertical machining center. It features a 255 mm diameter trunnion table and axis travels of 550 mm (X) by 508 mm (Y) and 520 mm (Z).
July 22, 2019
The rotary table offers +40/-120 degrees A-axis range and 360 degree C-axis. Equipped with either a 10,000- or 15,000-rpm 18 kW inline spindle, a 40-station swing arm ATC is standard. Utilizing the Milltronics Series 9000 control, the VM250IL-5x is designed for fast and easy five-sided parts.
  • machining center
