Episode 11: Too much chatter?
A grinding shop trying to grind a 0.006" radius into a hardened steel part with a 60-grit, vitrified-bond, aluminum-oxide wheel was having trouble with burn and huge chatter. Grinding Doc Jeffrey Badger explains how to handle the situation. Visit The Grinding Doc website for more advice from Dr.
A grinding shop trying to grind a 0.006″ radius into a hardened steel part with a 60-grit, vitrified-bond, aluminum-oxide wheel was having trouble with burn and huge chatter. Grinding Doc Jeffrey Badger explains how to handle the situation. Visit The Grinding Doc website for more advice from Dr. Jeffrey Badger at
Scroll for the next video
