Increase CNC Productivity with Lyndex-Nikken’s Precision Presetters
At Lyndex-Nikken, the team demonstrates the E346BA tool presetter—a mid-entry, granite-base tabletop model designed to improve shop efficiency by measuring tools offline and maximizing spindle uptime.
At Lyndex-Nikken, the team demonstrates the E346BA tool presetter—a mid-entry, granite-base tabletop model designed to improve shop efficiency by measuring tools offline and maximizing spindle uptime. With a 360mm diameter by 460mm height range, this presetter features a high-resolution camera with autofocus for checking multiple inserts, capturing diameter and Z-plane consistency without manual input. Operators can prep tools while machines are running, replacing outdated methods like 1-2-3 blocks and saving 15 to 60+ minutes per setup depending on shop size and workload. With a 15″ touch screen, optional tool-ID transfer, and compatibility with CAT, BT, and HSK spindles, the E346BA delivers precision, time savings, and reduced operator error—making it a smart investment for modern CNC operations.
