New QUICK3CHAM Heads for Boring and Enlarging Existing Holes
When surface finish, diameter, straightness, or roundness requirements are closer than traditional drilling operations can produce, it may be necessary to add a drill, endmill or single-point boring tool to the operation, often at the expense of poor chip control.
Sponsored ContentPresented by Iscar USA
November 1, 2025
Iscar introduces a new line of replaceable carbide heads for counterboring operations. The F3B heads feature chip deflectors for excellent chip control in a wide range of materials. They are offered in 0.1 mm (0.004″) increments from Ø12-25.5 mm (0.472-1.004″) and mount on standard tool bodies from the QUICK3CHAM drilling line. Three flutes provide improved quality three times faster than single point.
  • counterboring
    Enlarging one end of a drilled hole. The enlarged hole, which is concentric with the original hole, is flat on the bottom. Counterboring is used primarily to set bolt heads and nut…
Join the MFGAxis discussion
Scroll for the next video
