Take on Superalloys with NTK’s JRF Ceramic Milling Cutter
Meet the JRF Cutter, NTK’s high-efficiency small-diameter ceramic cutter for HRSA machining. This cutter features up to three negative, double-sided inserts on a cutter body ranging from 16 mm to 32 mm. The JRF is offered as both a shank type and modular type, providing versatility across a wide range of applications.
Meet the JRF Cutter, NTK’s high-efficiency small-diameter ceramic cutter for HRSA machining. This cutter features up to three negative, double-sided inserts on a cutter body ranging from 16 mm to 32 mm. The JRF is offered as both a shank type and modular type, providing versatility across a wide range of applications. Pair the JRF Cutter with NTK’s SX3 SiAlON ceramic grade for applications from roughing to semi-finishing. SX3 offers excellent wear resistance and thermal stability, helping maintain reliable performance and consistent results.
