IS0 1179 Port Tools
March 23, 2021
Cuts Minor Thread (BSPP) Diameter, 90 Degree Included Angle, Spot Face
Scientific Cutting Tools is expanding its offerings with the launch of the brand new ISO 1179 port tool. It cuts the minor thread (BSPP) diameter, 90 degree included angle, and the spot face per the requirements of ISO1179. The carbide-tipped port tool features brazed carbide inserts of the highest quality sub-micron carbide for optimal material properties. Smaller thread size port tools are three flutes and larger thread size port tools are four flutes. 1179 port tools have a polished flute face for the best performance. Items are stocked uncoated or AlTiN coated. AlTiN coating is highly recommended if cutting steel as the coating prevents the chip from sticking to the carbide. Additionally, AlTiN coating improves tool life and allows the tool to achieve a high-quality finish.
  • flutes
    flutes
  • included angle
    included angle
    Measurement of the total angle within the interior of a workpiece or the angle between any two intersecting lines or surfaces.
Additional Products from Scientific Cutting Tools Inc.
The SAEJ1926-X will cut the required spot face and O-Ring taper only; it does not cut the thread minor diameter. A coolant hole to each flute aids with increased chip evacuation, higher speeds and feeds, and longer tool life. The polished flute face optimizes performance for a smoother surface…
The AS5202-X will cut the required spot face and counterbore only; it does not cut the thread minor diameter. A coolant hole to each flute aids with increased chip evacuation, higher speeds and feeds, and longer tool life. The polished flute face optimizes performance for a smoother surface finish…
Cutting diameter sizes range from 1/8" to 1/2". Included angle options are 90° or 120°. The two-flute design is optimal when chip evacuation and increased chip per tooth are the priority. For harder materials, the fortified strength of the four-flute design performs best and allows for…
Scientific Cutting Tools has expanded the Single Point Thread Mill (SPTM) line with new sizes and lengths. The additional sizes include #5 and 7/16 for UN standards as well as larger M3 and M11 sizes for metric. The new extra long (XL) lengths were created for deeper threads. It is available in…
Scientific Cutting Tools offers the new SPTM EXJ thread mill. The SPTM EXJ is an economical tool engineered for cutting external UNJ threads. It features a single thread profile that is ideal for keeping side-cutting pressure low.
Scientific Cutting Tools Inc. announces a new line of high-performance helical chamfer mills. The helical cutters are significantly freer cutting and impart a smoother finish than the standard straight-flute alternatives. The variable-helical flute design provides high sheer, reduced side cutting…
Scientific Cutting Tools offers Coolant Ring Technology holders. CRT holders are made from high-quality heat-treated steel and come with a black-oxide coating. They are engineered to allow for better coolant penetration deep into the bore, reducing temperature at the cutting edge, according to the…
Scientific Cutting Tools Inc. (SCT) stocks UN thread mills for cutting from 4-40 up to 3-1/2-8, as well as NPT, BSPP and BSPT 1/16 to 2½ and up, according to the company based in Simi Valley, Calif. Except for staggered-tooth thread mills, all of SCT's solid-carbide, straight-flute thread…
