Single Point Thread Mill Line
August 02, 2019
Scientific Cutting Tools has expanded the Single Point Thread Mill (SPTM) line with new sizes and lengths. The additional sizes include #5 and 7/16 for UN standards as well as larger M3 and M11 sizes for metric. The new extra long (XL) lengths were created for deeper threads. It is available in both UN and metric. All tools are available uncoated or with AlTiN coating.
The new sizes and lengths join the recent expansion of SPTM tools including the EXJ (External UNJ). The SPTM EXJ is a great economical tool engineered for cutting external UNJ threads. It features a single thread profile that is ideal for keeping side-cutting pressure low.
The non-crest cutting design allows maximum flexibility for plated and non-standard threads. SPTM EXJ tools will cut any size external thread of the pitch listed. It is precision ground for maximum concentricity and meets the standards of MIL-SPEC 8879  and AS8879. SPTM thread mills are also available in Acme and Stub Acme thread forms.
  • milling machine ( mill)
  • pitch
    pitch
Additional Products from Scientific Cutting Tools Inc.
The SAEJ1926-X will cut the required spot face and O-Ring taper only; it does not cut the thread minor diameter. A coolant hole to each flute aids with increased chip evacuation, higher speeds and feeds, and longer tool life. The polished flute face optimizes performance for a smoother surface…
The AS5202-X will cut the required spot face and counterbore only; it does not cut the thread minor diameter. A coolant hole to each flute aids with increased chip evacuation, higher speeds and feeds, and longer tool life. The polished flute face optimizes performance for a smoother surface finish…
Smaller thread size port tools are three flutes and larger thread size port tools are four flutes. 1179 port tools have a polished flute face for the best performance. Items are stocked uncoated or AlTiN coated. AlTiN coating is highly recommended if cutting steel as the coating prevents the chip…
Cutting diameter sizes range from 1/8" to 1/2". Included angle options are 90° or 120°. The two-flute design is optimal when chip evacuation and increased chip per tooth are the priority. For harder materials, the fortified strength of the four-flute design performs best and allows for…
Scientific Cutting Tools offers the new SPTM EXJ thread mill. The SPTM EXJ is an economical tool engineered for cutting external UNJ threads. It features a single thread profile that is ideal for keeping side-cutting pressure low.
Scientific Cutting Tools Inc. announces a new line of high-performance helical chamfer mills. The helical cutters are significantly freer cutting and impart a smoother finish than the standard straight-flute alternatives. The variable-helical flute design provides high sheer, reduced side cutting…
Scientific Cutting Tools offers Coolant Ring Technology holders. CRT holders are made from high-quality heat-treated steel and come with a black-oxide coating. They are engineered to allow for better coolant penetration deep into the bore, reducing temperature at the cutting edge, according to the…
Scientific Cutting Tools Inc. (SCT) stocks UN thread mills for cutting from 4-40 up to 3-1/2-8, as well as NPT, BSPP and BSPT 1/16 to 2½ and up, according to the company based in Simi Valley, Calif. Except for staggered-tooth thread mills, all of SCT's solid-carbide, straight-flute thread…
