SAEJ1926 Port Tools
January 24, 2024
SAEJ1926 Port Tools Ideal for Non-Standard Thread Minor Diameters and Lengths
The SAEJ1926-X series is a brand-new style of port tools by Scientific Cutting Tools that meet the SAEJ1926/1 and MS16142 port specifications. This tool offering is ideal for non-standard thread minor diameters and lengths.
The tools have three flutes, are coolant through, and do not have a pilot diameter. This series is also designed to replace SCT’s line of piloted port tools. Historically, solid pilot tools were used to line up the tool to the hole when using manual milling or drilling equipment. With the widespread use of modern CNC equipment, the solid pilot is no longer necessary, and sometimes detrimental.
The SAEJ1926-X will cut the required spot face and O-Ring taper only; it does not cut the thread minor diameter. A coolant hole to each flute aids with increased chip evacuation, higher speeds and feeds, and longer tool life. The polished flute face optimizes performance for a smoother surface finish. The body of the port tool is made of heat-treated alloy steel and the brazed inserts are made of premium quality sub-micron carbide.
Tools are in stock and available to order either uncoated or AlTiN+ coated. For ferrous and hard-to-machine materials, the coated version is highly recommended.
  • coolant
  • flutes
    flutes
  • gang cutting ( milling)
  • milling
Additional Products from Scientific Cutting Tools Inc.
The AS5202-X will cut the required spot face and counterbore only; it does not cut the thread minor diameter. A coolant hole to each flute aids with increased chip evacuation, higher speeds and feeds, and longer tool life. The polished flute face optimizes performance for a smoother surface finish…
Smaller thread size port tools are three flutes and larger thread size port tools are four flutes. 1179 port tools have a polished flute face for the best performance. Items are stocked uncoated or AlTiN coated. AlTiN coating is highly recommended if cutting steel as the coating prevents the chip…
Cutting diameter sizes range from 1/8" to 1/2". Included angle options are 90° or 120°. The two-flute design is optimal when chip evacuation and increased chip per tooth are the priority. For harder materials, the fortified strength of the four-flute design performs best and allows for…
Scientific Cutting Tools has expanded the Single Point Thread Mill (SPTM) line with new sizes and lengths. The additional sizes include #5 and 7/16 for UN standards as well as larger M3 and M11 sizes for metric. The new extra long (XL) lengths were created for deeper threads. It is available in…
Scientific Cutting Tools offers the new SPTM EXJ thread mill. The SPTM EXJ is an economical tool engineered for cutting external UNJ threads. It features a single thread profile that is ideal for keeping side-cutting pressure low.
Scientific Cutting Tools Inc. announces a new line of high-performance helical chamfer mills. The helical cutters are significantly freer cutting and impart a smoother finish than the standard straight-flute alternatives. The variable-helical flute design provides high sheer, reduced side cutting…
Scientific Cutting Tools offers Coolant Ring Technology holders. CRT holders are made from high-quality heat-treated steel and come with a black-oxide coating. They are engineered to allow for better coolant penetration deep into the bore, reducing temperature at the cutting edge, according to the…
Scientific Cutting Tools Inc. (SCT) stocks UN thread mills for cutting from 4-40 up to 3-1/2-8, as well as NPT, BSPP and BSPT 1/16 to 2½ and up, according to the company based in Simi Valley, Calif. Except for staggered-tooth thread mills, all of SCT's solid-carbide, straight-flute thread…
