Model FC-700
July 01, 2011
Rush Machinery offers the large capacity Model FC-700 Series Diamond and CBN Wheel Truing and Dressing Machine. The Model FC-700 series is designed for truing and dressing of flats, angles, and radii on diamond and CBN single wheels and multiple wheel packs for wheels up to 28" (700mm) standard, with an option to 42" (1070mm) in diameter. Use of the Model FC-700 series allows for increased efficiency and accuracy by dressing wheels properly, offline of the production grinding machinery. The machine is simple to operate, quick, accurate and cost-effective.
The heavy-duty one-piece cast iron base provides extra rigidity and minimizes vibration. Standard features include a computer-driven vision system with a software program specifically designed for the FC-700 series truers and their various applications; an automatic power zoom; and, a 2-axis DRO for measurement.
The Model FC-700 series is available as a manual machine (FC-700W) or a semi-automatic version (FC-700EX). The FC-700EX utilizes an advanced PLC control for semi-automatic wheel dressing cycles, thereby freeing up the operator for other nearby tasks.
The customized video software platform makes high-tolerance truing and dressing easier than ever before. In addition to the auto-zoom capabilities, this system allows magnification levels from 15x to 60x as standard; and, an optional high magnification system that allows from 30x to 120x, giving the benefit of true continuous in-process optical inspection while you work.
  • cubic boron nitride ( CBN)
  • dressing
    dressing
  • grinding
  • truing
    truing
    Using a diamond or other dressing tool to ensure that a grinding wheel is round and concentric and will not vibrate at required speeds. Weights also are used to balance the wheel. Also performed to impart a contour to the wheel’s face. See dressing.
  • vision system
    vision system
Additional Products from Rush Machinery
Designed for cutting tool manufacturers and carbide rod processors, this production machine can significantly increase your production rate for cutting carbide and hardened steel rod when compared with manual cut-off machines. It's easy-to-use CNC controls and touch screen operator interface…
The Truing Parameters Calculator is the result of a 3-year collaboration between Rush Machinery, the International Grinding Institute, and Dr. Jeffrey Badger, the ‘Grinding Doc’. Rush Machinery commissioned the project that was later presented at the 2008 CIRP General Assembly in Tokyo by…
The CH-CM0406 Cut Pre-Point Chamfer Machine makes carbide blanks that are ready for tool grinding. The machine converts blank carbide rods into tool blanks. It is suitable for cutting tool manufacturers that want to make tools from a blank that is already pre-pointed and chamfered. The machine is…
Rush Machinery offers the Model FC-350EX and Model FC-350W wheel truing and dressing machines, designed for truing and dressing flats, angles, and radii on diamond and CBN single wheels and multiple wheel packs.
Rush Machinery is offering the CH-CM0203 CNC Carbide Rod Chamfer Machine for chamfering blanks for carbide and HSS cutting tools. The machine comes equipped with a large-capacity magazine, an automatic loader, a flood coolant system, 2-axis servomotor and servo amplifier, and fully automatic CNC.
The 2 Rod “Auto-Cut” CNC Carbide Cut-Off Machine automatically cuts carbide rod into precision lengths. This production machine, designed for cutting tool manufacturers and carbide rod processors, has a large-capacity magazine and an automatic loader to provide hours of unattended operation.
Rush Machinery offers the new Rush Easy-Cut XL semiautomatic carbide cut-off machine for quick and easy cutting of carbide flat stock up to 2”x4” or rod and tool ends with diameters between 1/8” to 2”.
The BMT-150M On-Machine Balancing Kit from Rush Machinery for balancing wheels and wheel packs on truers or grinding machines. The kit comes with everything you need to get started.
Rush offers the Models FC-200D, FC-300D, FC-500D and FC-200CNC polycrystalline tool grinders, which allow for economical manufacturing and regrinding of PCD, CVD, PCBN, carbide and HSS tools. These machines grind angles and radii on standard and special turning and milling inserts, boring tools,…
Rush Machinery Inc.'s Drill and Tool Grinders have helped thousands lower their holemaking costs through higher precision, faster production, less down time and reduced tool inventory.
