Rush Machinery Grinding machines
April 01, 2010
Grinding machines from Rush Machinery Inc. produce carbide and HSS drills and other cutting tools, including taps, reamers, countersinks and endmills. According to the company, the machines grind almost any point, and end users can exchange the standard workhead in less than a minute with an optional air-bearing attachment for grinding endmill ODs. Manual bench top and automatic-infeed floor models are available with capacities from 0.080" to 1¼", 3⁄32" to 2" and 3⁄16" to 31⁄8".
  • endmill
    endmill
  • grinding
  • high-speed steels ( HSS)
Additional Products from Rush Machinery
Designed for cutting tool manufacturers and carbide rod processors, this production machine can significantly increase your production rate for cutting carbide and hardened steel rod when compared with manual cut-off machines. It's easy-to-use CNC controls and touch screen operator interface…
The Truing Parameters Calculator is the result of a 3-year collaboration between Rush Machinery, the International Grinding Institute, and Dr. Jeffrey Badger, the ‘Grinding Doc’. Rush Machinery commissioned the project that was later presented at the 2008 CIRP General Assembly in Tokyo by…
The CH-CM0406 Cut Pre-Point Chamfer Machine makes carbide blanks that are ready for tool grinding. The machine converts blank carbide rods into tool blanks. It is suitable for cutting tool manufacturers that want to make tools from a blank that is already pre-pointed and chamfered. The machine is…
Rush Machinery offers the Model FC-350EX and Model FC-350W wheel truing and dressing machines, designed for truing and dressing flats, angles, and radii on diamond and CBN single wheels and multiple wheel packs.
Rush Machinery is offering the CH-CM0203 CNC Carbide Rod Chamfer Machine for chamfering blanks for carbide and HSS cutting tools. The machine comes equipped with a large-capacity magazine, an automatic loader, a flood coolant system, 2-axis servomotor and servo amplifier, and fully automatic CNC.
The 2 Rod “Auto-Cut” CNC Carbide Cut-Off Machine automatically cuts carbide rod into precision lengths. This production machine, designed for cutting tool manufacturers and carbide rod processors, has a large-capacity magazine and an automatic loader to provide hours of unattended operation.
Rush Machinery offers the new Rush Easy-Cut XL semiautomatic carbide cut-off machine for quick and easy cutting of carbide flat stock up to 2”x4” or rod and tool ends with diameters between 1/8” to 2”.
The BMT-150M On-Machine Balancing Kit from Rush Machinery for balancing wheels and wheel packs on truers or grinding machines. The kit comes with everything you need to get started.
Rush offers the Models FC-200D, FC-300D, FC-500D and FC-200CNC polycrystalline tool grinders, which allow for economical manufacturing and regrinding of PCD, CVD, PCBN, carbide and HSS tools. These machines grind angles and radii on standard and special turning and milling inserts, boring tools,…
Rush Machinery Inc.'s Drill and Tool Grinders have helped thousands lower their holemaking costs through higher precision, faster production, less down time and reduced tool inventory.
