Designing a Special for a Legacy Part
800-338-0276 www.tritecmfg.com
Tri-Tec Manufacturing
SOLUTION PROVIDER
Heule Tool Corp. 513-848-7235 www.heuletool.com
CHALLENGE
Re-manufacture a part in which the original back spot-facing toolâs limited diameter range wouldnât have worked for the larger spot facing needed and the indexable insert for the tool was no longer available.
SOLUTION
Aspecial back spot-facing tool. Tri-Tec Manufacturing designs and builds remote actuation assemblies, such as vent valves and actuators, for U.S. Navy ships.
The parts are often installed in critical safety systems like flood boundaries and must withstand demanding conditions. These ships typically stay in service for decades, which can create challenges for the Kent, Washington-based manufacturer. In addition to providing new OEM components, Tri-Tec services older parts as well, which is an area that often leads to problems when the original tools used to create the part initially are no longer supported by the vendor. That was the case when they received a Navy actuator housing for repair.
The job required re-machining a critical surface deep inside a bronze casting, accessed through a narrow hole. It was a long-serving part, but the previous tools were not available. Tri-Tec needed a viable solution â fast â and called Heule Tool Corp. in Loveland, Ohio, based on the manufacturerâs success with the toolmakerâs back boring products.
âShips have 40-, 50-year lives, so a lot of things we do, weâre going to keep doing down the road,â said Mark Smith, lead manufacturing engineer at Tri-Tec, which supports ongoing repair work and maintains critical components throughout the life of the fleet. Sometimes, Tri-Tec has to rework a decades-old part and is constantly addressing new challenges as tools and technology evolve. âWe have more than 20,000 unique part numbers,â Smith said, âbut, oftentimes, our orders will be 10 or 15 parts. Weâre almost like a job shop in that way.â Tri-Tec first purchased a B series 11 mm (0.43") back spot-facing tool for a Navy repair application to replace an unsupported BSF tool, for which the indexable insert was no longer available.
The manufacturer uses this tool to produce a long-established design part. However, as new development projects arose, Tri-Mec purchased an A series BSF-A-650/040-7.0 with BSF-M-A-1A-6.0 to do the 13.21 mm-dia.
(0.520") BSF for a new development projectâs version â1â prototype. This tool was used for a part with interrupted cuts. Ongoing support from Heule reportedly provides a bridge between Tri-Tecâs older applications and new developments, helping the manufacturer continue to serve clients with effective solutions.
The actuator housing being prototyped in this case was made from C86300 manganese bronze. Inside the casting, four raised mounting pads needed to be machined to create smooth, flat surfaces to support a transformer. These back spot faces needed to be cut from inside the housing, through a 6.53 mm (0.257") access hole, to a finished diameter of 13.21 mm.
One face was right up against a raised boss, creating an interrupted cut and leaving little room to work. In the past, Tri-Tec used a similar indexable BSF tool for this type of work. The tool had a small shank that could pass through a hole and expand to cut on the far side. It was a setup that had worked for years, but the insert line was discontinued.
View print ads from this spread
Review the ads on this magazine spread to continue reading. Each ad takes two seconds; a two-page ad counts once.
Advertisers on this magazine spread
Print placements on this magazine spread
XACT Wire EDM
Coolant Hole Expertise
XACT Wire EDM promotes coolant-hole machining for cutting tools, end mills, reamers and taps.
XACT Wire EDM highlights coolant-hole machining with small electrodes, tight tolerances and deep hole ratios.
Visit XACT Wire EDM View this placement in the issue recordPrint ads from this magazine
Continue reading
May 2026
Even if it had still functioned, the toolâs limited diameter range wouldnât have worked for the larger spot facing needed. In Navy work, older designs are common. Tri-Tec was working on a part that had to be kept in service, but the tooling setup for that part no longer worked. With no way to repeat the original process, the team needed a new, supported solution that could meet the same specs and remain available for future repairs.
Smith had previously worked with Heule on a job involving a silicon brass housing for fiber optic cable mounts. When the actuator housing presented this new set of challenges, he knew where to turn. Support includes engineering, an in-house test center that helps validate ideas before implementation and an extensive North American network of sales partners and distributors. Heuleâs standard lines cover both front and back hole operations, and roughly half of its business comes from custom-engineered approaches tailored for unique applications.
Smith worked with Matt Clark of Clark Manufacturerâs Service LLC, Heuleâs representative in Seattle, to evaluate the partâs geometry and cutting requirements. Together, they selected a Heule back spot-facing tool (BSF-A-0650/040-7.0) that could reach through the 6.53 mm hole and cut a clean 13.21 mm flat on the far side of the part.
No additional fixturing was needed to use the BSF tools. The only process change, compared to the obsolete tool, was to rough drill the through hole to match the BSF tool, then open it up to final size after the BSF tool cut the part. Heule tools feature retractable cutter mechanisms, so the blade expands inside the part and retracts after the cut is completed. This eliminates the need for custom fixturing or multiple-step setups while preserving accuracy and surface quality.
The interrupted cut path caused by the raised boss required some adjustments. Smith said the team tuned their feeds and speeds to stabilize the toolpath and complete the cuts successfully. âIt proved to be problematic just because of the nature of the casting and the interruption, but once we dialed in on what we were doing there, it worked flawlessly.â Only two housings were prototyped before the part was redesigned, but Smith said the new layout may still include internal machining features.
More importantly, the success of this prototype job opened the door for future applications. Tri-Tec uses the same Heule tool setup to remanufacture other parts that were originally produced decades ago. Smith emphasized the importance of having tools that remain available and supported long after the original job is completed, even for small batches. âWe may only make a few of something, but we need the tools and process to work every time.
Especially in Navy work, these parts donât just go away. They come back in for repair, even decades later.â For shops like Tri-Tec, choosing tooling partners is about more than cycle times or unit cost. Smith said repeatability, technical support and long-term availability matter the most.
Captions: Credit: All images: Heule Tool
(100_4497.jpg) The actuator housing Tri-Tec Manufacturing was prototyping was made from C86300 manganese bronze. Inside the casting, four raised mounting pads needed to be machined to create smooth, flat surfaces to support a transformer. (Heule Back Spot Facing Tool.jpg) Heule tools feature retractable cutter mechanisms, so the blade expands inside the part and retracts after the cut is completed. Pull Quote: âWe have more than 20,000 unique part numbers, but, oftentimes, our orders will be 10 or 15 parts. Weâre almost like a job shop in that way.â
