Multi-axis CNC turn-mill center with direct-drive turret system
Eurotech Elite's Trofeo BMX Series delivers dual spindles at 10K RPM, 15 HP driven tools, and 15-station turrets supporting up to 110 tools. The Trofeo BMX features a direct-drive turret system, which is a tool-holding mechanism designed for rapid indexing, high precision, and maximum rigidity in multi-axis CNC turn-mill centers.
May 5, 2026
Eurotech Elite’s Trofeo BMX Series delivers dual spindles at 10K RPM, 15 HP driven tools, and 15-station turrets supporting up to 110 tools.
The Trofeo BMX features a direct-drive turret system, which is a tool-holding mechanism designed for rapid indexing, high precision, and maximum rigidity in multi-axis CNC turn-mill centers. The system gives the user faster response, greater rigidity, reduced maintenance, quieter operation, superior torque, and improved thermal stability, the company says.
With thermally stabilized integrated motors and a more rigid, efficient turret design, the Trofeo BMX helps shops achieve better surface finishes, shorter cycle times, less downtime and long-term reliability.
