How to Get the Most from ISO and Proprietary Inserts
All businesses feel the pressure to improve productivity, precision and profitability. For machine shops, one of the most influential decisions — yet often misunderstood — involves choosing the right turning insert for the job. With countless insert types, coatings and geometries available, understanding when to use ISO-standard inserts versus proprietary options can significantly impact your throughput, part quality and tool life.
To be clear, insert selection is just one part of a larger process. The biggest mistake machine shops make is not picking the wrong insert, it’s choosing the wrong machine for the job in the first place. The machine, the insert, the workholding and the application all need to work together. At the same time, shops can make smarter decisions and fully optimize turning performance, starting with inserts.
ISO Versus Proprietary Inserts
Often thought of as a universal fit of the turning world, ISO inserts are standardized internationally across the industry and are typically interchangeable among manufacturers. They offer flexibility, wide availability and competitive pricing.
Proprietary inserts, on the other hand, go beyond ISO standards and are designed by a specific tooling company to offer unique geometries or functions. They are brand-specific and often come at an upfront premium, but proprietary inserts can boost chip management, extend tool life, or enable multi-function turning. Choosing proprietary makes sense when an application demands it. For instance, when a machinist is chasing extreme chip control for automated turning or when a part requires multiple cutting operations in one setup, proprietary inserts and the right machine tool provide the best return on investment.
4 Steps to Optimize Turning with ISO and Proprietary Inserts
Step one. Begin with the right machine, not just the right tool. Insert performance is only as good as the platform it runs on. Shops sometimes buy a lower-cost machine that limits rpm or lacks rigidity, and that is when tool life and cycle time get compromised.
Before selecting inserts, evaluate the machine’s rpm range compared to insert requirements, workholding rigidity, output, and coolant delivery capability. Through evaluation results, shops could discover that $5,000 saved on a chuck or a $20,000 compromise on machine speed could cost $30,000 to $50,000 in added tooling for the year.
Step two. Match insert geometry and grade to the material and operation. Whether you are working with steel, titanium, aluminum or a newly developed metal that just hit the market, every material requires a specific insert grade and geometry. Many shops mistakenly default to general-purpose CNMGs without matching chipbreaker design or coatings to the actual application.
View print ads from this spread
Review the ads on this magazine spread to continue reading. Each ad takes two seconds; a two-page ad counts once.
Advertisers on this magazine spread
Print placements on this magazine spread
CTE Daily Grind
CTE Daily Grind house ad
CTE Daily Grind house ad printed on folio 19 / physical PDF page 21; United Grinding was deferred to September under the documented production disposition.
Print page 21
View this placement in the issue record
Be sure to use CVD coatings for high-speed roughing of materials like steel or cast iron and PVD coatings for finishing or when cutting stainless steel and superalloys. Use depth of cut and feed rates as a guide to select insert geometries. Roughing, for example, calls for a stronger, tougher edge with larger nose radius. Finishing on the other hand, needs a sharper insert edge with fine chip control features. It can be tempting to just see a turning part and grab the same CNMG every time. Pausing to consider how insert geometry interacts with material hardness and chip formation can be the difference between completing a profitable job or losing money from wasted material and time.
Step three. Be strategic about when to use proprietary inserts. Proprietary inserts are not always necessary, but in the right context they can reduce cycle time, improve surface finish, or eliminate secondary operations. Consider proprietary inserts for tight-tolerance parts that ISO geometries struggle to finish, such as for high-mix, low-volume jobs where flexibility is key, turn-mill or multitasking machines with limited tool stations, and materials with the potential for complex chip behavior.
Step four. Think beyond the price of an individual insert. Shops often focus on the upfront cost of the insert, but it is a fraction of the total investment of machining. Slower cycle times, shorter tool life, and poor part finishes all lead to lost revenue. Examine the cost per insert edge versus parts produced per shift by factoring in setup time, rework and scrap rate. Ultimately, shops need to look at tool performance over months, not days. It is very possible an insert that costs a few dollars more upfront saves thousands of dollars per job because it works faster and longer.
Ask Your Tooling Supplier for Help
Turning inserts do not exist in a vacuum and neither do job shops. Bring tooling suppliers into the shop during project planning. Ask them to work on the action steps with you. Whether you stick with standard ISO options or leverage cutting-edge proprietary technology, success comes from understanding the application and making decisions that align with part prints, machines, materials and business objectives. A trusted and skilled tooling partner will provide the best insert options for your production environment and walk your team through material behavior, chip control, coatings and insert geometry.
— Eric Gerringer, Technical Director, CERATIZIT USA
Join the MFGAxis discussion
Sign in with innoNET Subscribe to CTE Connect my subscription
