Lead Angle for April 2026
Precision in today’s machining environment isn’t just about holding tighter tolerances, it’s about recognizing the larger picture — the full process, from material behavior to tooling strategy to how parts ultimately perform in the real world.
Precision in today’s machining environment isn’t just about holding tighter tolerances, it’s about recognizing the larger picture — the full process, from material behavior to tooling strategy to how parts ultimately perform in the real world. The articles in this issue of Cutting Tool Engineering sharpen the focus on that picture, pinpointing how shops can improve outcomes by refining both their thinking and their processes. We begin with a deep dive into the world of medical moldmaking, where the stakes couldn’t be higher. In “A Critical Application,” CTE Editor-at-large Alan Richter explores how companies like SyBridge Technologies approach injection mold tooling for medical devices — an environment where microns matter, but precision is ultimately measured in long-term reliability.
The article underscores how design for manufacturing and process capability, particularly achieving consistent Cpk levels, are critical to producing parts that perform as intended over millions of cycles. It’s a reminder that success in machining isn’t just about hitting dimensions — it’s about ensuring repeatability and real-world functionality. Thermal control plays an equally critical role, especially when working with demanding medical alloys. In “Keeping Cool,” Sandvik Coromant Product Specialist Manager Mike Marchand explains why heat management has become a defining factor in machining titanium and cobalt-chrome.
From through-tool high-pressure coolant to modern fluid management strategies, the article outlines how controlling temperature directly impacts tool life, surface integrity and part performance. There’s a clear message for shops pushing into medical or high-precision work: stability in the cut leads to stability in the outcome. Tooling strategy is another area where careful decisions can yield outsized results. In “Advanced Cutting Materials in Turning,” Erez Speiser, the founder of the Machining Doctor website, challenges the assumption that higher tool cost always means higher expense.
View print ads from this spread
Review the ads on this magazine spread to continue reading. Each ad takes two seconds; a two-page ad counts once.
Advertisers on this magazine spread
Print placements on this magazine spread
Sandvik Coromant
Get a 30% boost
Sandvik Coromant promotes CoroCut 2 with grade GC1225 as a more reliable, cost-effective parting and grooving option for ISO P steel.
Sandvik Coromant promotes CoroCut 2 with grade GC1225 for a higher price/performance ratio and more secure parting off in ISO P steel. Visit sandvik.coromant.com/corocut2 to learn more.
Print page 5
Visit Sandvik Coromant View this placement in the issue record
By examining when materials like CBN, ceramic and PCD make sense, the article shows how the right tool can reduce cycle time, eliminate secondary operations and lower total cost per part. It’s a practical look at matching capability to application — and understanding when premium tooling truly pays off. Of course, not every improvement comes from advanced materials or high-tech solutions. Sometimes, it’s about revisiting the fundamentals.
“Drilling Deserves More Respect” by CTE contributor Christopher Tate makes a compelling case for one of the most overlooked processes in modern CNC shops. With higher material removal rates, lower tooling costs and simpler programming, drilling often provides a faster and more economical alternative to milling for holemaking — yet it’s frequently sidelined. That same practical mindset carries into this issue’s shop-floor insights. In “Tiny Cuts Can Be a Real Grind,” CTE contributor and podcaster Robert Layng shares straightforward but effective techniques for grinding aluminum, including creative workholding methods and a simple anti-loading solution using WD-40.
It’s a reminder that even in a high-tech industry, ingenuity and hands-on experience still drive results. Finally, Brandt Taylor’s look at machining ASTM A193 B7 steel in his Machinist’s Corner column this month reinforces a principle that applies across all machining operations: more aggressive isn’t always better. By controlling speed, feed and heat generation, shops can preserve material properties and avoid costly part rejection. Taken together, the articles in this issue highlight a common theme: machining excellence comes from understanding the interaction between tools, materials and processes — and making informed decisions at every step.
Whether you’re working on high-volume production or specialized components, those insights can make the difference between simply making parts and truly mastering the process.
Join the MFGAxis discussion
Sign in with innoNET Subscribe to CTE Connect my subscription
