Making the Grade
Author Bill Kennedy
June 01, 2002 - 12:00pm
Application-specific PCBN grades enhance metalcutting operations.
Read the Full Article
  • metalcutting ( material cutting)
  • polycrystalline cubic boron nitride ( PCBN)
    Cutting tool material consisting of polycrystalline cubic boron nitride with a metallic or ceramic binder. PCBN is available either as a tip brazed to a carbide insert carrier or as a solid insert. Primarily used for cutting hardened ferrous alloys.
Author
Contributing Editor
Bill Kennedy, based in Latrobe, Pa., is a former contributing editor for Cutting Tool Engineering. He has an extensive background as a technical writer.
Sponsored Content
