When holding parts for milling operations, the geometry of the part determines how best to clamp it. For parts with flat surfaces a vise is often the best solution. Figure 1 shows a typical milling vise. For round parts a scroll mounted on an index might be best. Figure 2 shows such a tool.
The vise in Figure 1 has a wedge arrangement in the sliding jaw. That feature improves accuracy and is important. The screw that tightens the vise pushes against a wedge that slides in the vise bed. That wedge pushes against another wedge with opposite geometry that is attached to the sliding jaw.
The result is that the clamping force between the movable and stationary jaws is matched by an equal force that pushes the movable jaw against the vise bed. This prevents the movable jaw from tilting and rising relative to the fixed jaw, and thus holds the clamped part square in the vise jaws. Vises without this feature introduce error in the clamping operation, and make for less accurate machining.
These wedge clamp vises have been around for a lot of years, and there are many manufacturers. Some take care with accuracy, grinding all the mating faces. Some, not so much. Years ago, a tool salesman told me, “An inaccurate tool is an expensive tool; an accurate tool is a good tool.” So true.
If you have a setup with multiple vises, it is really nice to have vises with identical dimensions.
Figure 2 shows an index I have had for 40 years. I use it for clamping round parts because it is accurate and durable. Round parts can be clamped with a milling vise with machined soft jaws or vise jaw accessories, but I use the scroll chuck index, if possible, especially if machining multiple parts. The clamping surface of a round part may have a diameter tolerance that could put the part off center if clamped with a vise. With a scroll chuck the clamping action centers the part on the chuck for better results. Finally, both vise jaws and chuck jaws can be made from soft material and can be machined for a workpiece with a special geometry. Soft jaws for milling vises and scroll chucks are available from tool distributors. Some milling vises on the market have the jaw bolt hole location at variance from other manufacturers, so beware of that when buying a vise.
Some of the specialty vise jaws have unique features that can be handy. I have a vise jaw set that has hydraulics in one jaw so six parts can be clamped simultaneously. You don’t want to be precluded from a clamping option because the vise you have has an unusual bolt pattern. The index I use has American Standard 8" chuck tongue and groove jaws, which are interchangeable with the jaws on an 8" chuck I have on a lathe. That simplifies things when machining soft jaws. I can machine soft jaws on the mill or lathe for use on the other machine. More about that in my next article. Details are important.
- centers
centers
- chuck
chuck
- flat ( screw flat)
flat ( screw flat)
- grinding
- lathe
lathe
- milling machine ( mill)
- tolerance
tolerance
