RobotWorx announces partnership with Octopuz Inc.
RobotWorx, an Ohio based company that focuses on quality industrial robotic solutions and customized integration, has announced a strategic partnership with Octopuz Inc. The new collaboration will allow RobotWorx to expand its service offerings into offline robot programming with a leading software creator.
February 10, 2020
While traditional robotic programming requires downtime and manual manipulation of a teach pendant, Octopuz provides a better solution. Octopuz enables path-sensitive, complex robot applications to be programmed without disruption to the manufacturing process.
How it Works
Users create detailed virtual simulations of their real-world robot cells, complete with machinery and manufacturing components, in minutes. Within this virtual cell, Octopuz uses built-in machine logic to automatically identify the optimal toolpath trajectory and program the required code for a multitude of industrial tasks. The code is then accurately converted to the robot brand's unique language for use in the real world.
Octopuz removes the traditional limitations of robot automation by enabling robot programming to be completed virtually, on a computer, while the robots are still online and working for you.
Maximize Robot ROI
RobotWorx provides this new solution to its existing and new customers with several benefits:
Simplify toolpath programming - An Intuitive, user-friendly software interface enables nonexperts to confidently program complex robot applications. Program through import from CAD or CAM software or natively in Octopuz.
Automatically detect and avoid errors - Quickly resolve potential toolpath errors including singularities, joint limits, reach limits and collisions.
Validate robotic processes through simulation - Ensure the robot will perform tasks as expected through start-to-finish simulation.
Program and post multiple-robot cells - Program, simulate and generate code for multiple robots in a single cell.
Single platform for all robot brands - Extensive component library with support for many robot brands in any configuration.
Support for all robot manufacturing processes - Support for welding, machining, cutting, spraying, additive and everything in between.
Reduce production downtime - Reprogram new robot functions in hours rather than days, without ever taking the robot offline.
