12-inch Fully Automatic Dual Post-Production Bandsaw
Designed to cut a wide range of metals, the 12-inch fully automatic, dual post-Production bandsaw from Palmgren was built for extreme production needs that require high output and heavy-duty performance.
Designed to cut a wide range of metals, the 12-inch fully automatic, dual post-Production bandsaw from Palmgren was built for extreme production needs that require high output and heavy-duty performance. The bandsaw provides exceptionally tight tolerances in cutting repeatability and accuracy even at high cutting rates. Its rigid design reduces vibration and delivers a superior surface finish.
