13 x 40-inch Engine Lathe
Operators will appreciate the easy-to-use control panel. For enhanced safety, the #9684526 Engine Lathe is equipped with a tool post guard, a chuck guard, a full rear splash guard and has CSA certified electronics.
February 12, 2024
Palmgren's high performance 13 x 40-inch Engine Lathe has the power, accuracy and versatility to handle a wide range of turning applications from heavy metal removal to fine tolerance turning operations.
The all-purpose lathe is well-suited for tool rooms, die and mold shops, fabrication shops and maintenance departments. It features an electronically controlled variable speed inverter to ensure complete control over the spindle RPM allowing operators to achieve the perfect speed for a project. The headstock provides maximum power and precision with every turn.
