The 16-inch variable-speed drill press from Palmgren was designed with the latest drilling technology and operation features to enhance output and accuracy. What separates it from the competition is its efficiency, safety and ergonomics.
The unique combination of V-belt and variable-speed converter reportedly provides the broadest speed range available today. It is equipped with electronic inverter, tapping mode, coolant, work light and safety interlocks on belt and chuck guards.
The #9680217 drill press fcan be used to perform drilling, tapping, reaming, boring, spot-facing, counterboring and chamfering in any type of material.
- boring
boring
- chamfering
chamfering
- chuck
chuck
- coolant
- counterboring
counterboring
Enlarging one end of a drilled hole. The enlarged hole, which is concentric with the original hole, is flat on the bottom. Counterboring is used primarily to set bolt heads and nuts below the workpiece surface.
- drilling machine ( drill press)
Machine designed to rotate end-cutting tools. Can also be used for reaming, tapping, countersinking, counterboring, spotfacing and boring.
- tapping
tapping
