Air-Operated Bench Presses
Air-operated bench presses from Palmgren reduce the cost of both implementation and production in assembly and pressing operations.
September 1, 2015
Air-operated bench presses from Palmgren reduce the cost of both implementation and production in assembly and pressing operations. They are ideally suited for transforming, joining and other operations that require forces from a few pounds to several tons.
These small, compact presses are the choice when precision matters for crimping, bending, forming, pressing, swaging, riveting and burnishing, according to the company. The bench presses feature a nonrotating double acting ram, which eliminates guide pins on most tooling jobs. The chrome plated piston resists rust to ensure a long operating life.
  • burnishing
    Finishing method by means of compressing or cold-working the workpiece surface with carbide rollers called burnishing rolls or burnishers.
