Barracuda Triple Action Lubricant
JTM Products Inc. has announced a new generation industrial multipurpose penetrant/lubricant. Barracuda Triple Action Lubricant has a proprietary formulation that penetrates, cleans and protects metal. It penetrates and breaks-free seized fasteners better than the leading consumer penetrant. With a unique chemistry, it works quickly, attracting it to metal to help break loose corroded bolts, nuts, screws, pipe joints and other industrial parts.
Barracuda Triple Action Lubricant also is an outstanding metal cleaner, and can be used to quickly remove grease, grime and rust from metal surfaces without requiring harsh solvents or the over-powering odor of other similar products. The product is also a superb protectant, removing water with a moisture-displacement property that wicks it away from metal surfaces while providing a thin, imperceptible protective film. Independent laboratory salt-spray testing has proven it superior to other commercially available lubricants as a rust inhibitor on metal surfaces and parts.
Barracuda Triple Action Lubricant is also ideal for use on stamping blanks and dies for aluminum or steel coil or sheet stock. Additionally, it rust proofs machine tables, chucks, ways, gears bushings, tools or implements susceptible to corrosion from high humidity. It is available in 11 oz. aerosol can, 1 gallon (3.79 liter) jugs, 5 gallon (19 liter pails) or 55 gallon (208 liter) drums.
