Coromant Capto C10
For all types of heavy machining operations in large components, Coromant Capto size C10 from Sandvik Coromant improves performance by allowing higher feeds and greater depths of…
For all types of heavy machining operations in large components, Coromant Capto size C10 from Sandvik Coromant improves performance by allowing higher feeds and greater depths of cut. A flange diameter of 3.937 inches means a coupling suitable for heavy loads providing extreme stability in milling and turning applications.
Designed to increase removal capacity at higher torques, the C10 gives the entire tool set up higher bending strength. The C10 includes a wide range of holders and adapters from shrink fit, SL adapters and ER- chucks to tap adapters.
