CSD-300II Front Facing Twin Spindle Lathe
For exceptionally quick and accurate turning of a variety of parts, turret index times are as low as .19 seconds, robot cycle times 17.9 seconds and loading times 4.8 seconds. An optimized bed design, with a grooving width of 14mm, renders this lathe exceptionally rigid.
The newly designed CSD-300II Front Facing Twin Spindle Lathe will be on display in booth 339059 at IMTS 2020. The latest generation of Fuji's CSD Series, and an upgrade to the CSD-300 Twin Spindle Lathe, the CSD-300II is more robust, with increased rigidity, and loaded with new and improved features for faster, easier and stronger operation.
Impressively productive, the CSD-300II achieves faster robot traverse and turret indexing speeds than its predecessor. For exceptionally quick and accurate turning of a variety of parts, turret index times are as low as .19 seconds, robot cycle times 17.9 seconds and loading times 4.8 seconds.
Operation and changeover are easier and more efficient than ever with the CSD-300II. The horizontal lathe is equipped with an innovative new dual gantry robot and the latest FANUC controls. In addition, the CSD-300II features an improved custom HMI and a single integrated Fanuc control panel that allows for convenient operation and setup of the machine and robot. A clamp/unclamp switch for the robot chuck and the robot's centralized lubrication system are included as standard. What's more, the CSD-300II comes ready to quickly connect to IoT, including Fuji's LAPSYS desktop software. Available as an option, LAPSYS reads scanned laser etchings to trace the origin of a part, including machine and spindle, and enables part traceability, predictive maintenance and remote operation.
Providing maximum material handling from a compact 2260mm x 1980mm footprint, the CSD-300II accurately manages heavy parts Ø 200mm x 100mm and 5kg + 5kg. The CSD-300II also features a Fuji-engineered hydraulic clamping loader and 8" – 10" capacity chucks.
Fuji turns the machining of a part into process perfection. When you contact Fuji, the part you will be machining is analyzed by engineers with vast experience in process and manufacturing engineering. With the largest install base at the major automotive manufacturers, Fuji engineers apply their experience with the Fuji machines that are built for automation from the ground up. These highly accurate machines employ built-in robotic automation, in-process auto gauging for quality control, and are engineered with the finest Fuji custom workholding, all from one source. This allows Fuji engineers to guarantee takt time, cycle time and CPK with turnkey and run-off solutions that are built for lean manufacturing. Using less manpower and more automation, Fuji machines produce the highest quality parts most efficiently and reliably. Fuji solutions are supported by factory-trained engineers 24/7.
