E-Weld Plasma
E-Weld Plasma
Walter Surface Technologies announces the launch of E-Weld Plasma, a ceramic, water-based, anti-spatter solution that is applied to laser and plasma cutting tables to reduce slag build-up. E-Weld Plasma offers a simple, yet efficient means of providing long-lasting protection, even under extreme heat, by inhibiting the adherence of slag.
April 19, 2017
E-Weld Plasma is applied to plasma and laser cutting tables with an ergonomic arm-mounted applicator. Users can quickly and easily coat areas as large as 500 square feet. E-Weld Plasma is applied by painting or spraying.
"E-Weld Plasma is a unique solution that decreases equipment maintenance time and eliminates the health and safety hazards associated with current cleaning processes for laser and plasma cutting tables," explained Jonathan Douville, product manager, Surfox, E-Weld and Finishing Solutions at Walter Surface Technologies. "This is an exciting unveiling for our industry. E-Weld PlasmaT provides great surface protection which increases the service life of work tables and makes cleaning operations much faster and safer."
E-Weld Plasma provides a significant productivity boost to metal fabricators that have to contend with extended downtimes to maintain their work tables. E-Weld Plasma is a label-free product that is applied in minutes and dries quickly. It reduces cleaning time from days to a few hours, depending on size of the work tables.
As an added benefit, the product can also be applied to surrounding equipment that is exposed to weld spatter or slag.
