MagVISE Workholding Chucks
Techniks says its MagVISE workholding chucks are fast, reliable and save 50-60 percent on setup time.
August 1, 2015
Techniks says its MagVISE workholding chucks are fast, reliable and save 50-60 percent on setup time. Magnetic workholding also provides the freedom to machine on four sides and the top of the workpiece, so you can cut more metal faster. Magnetic workholding is used for facemilling, edge milling, drilling and even boring on thick or thin workpieces.
MagVISE chucks quickly pay for themselves in time saved and increased production, according to the company. MagVISE chucks are available in a wide variety of types and sizes to fit all machines. From large dedicated chucks, to modular types and custom chucks built to exact specifications, the company offers them. Techniks even makes chucks for 4- and 5-axis machining and vertical turning applications. MagVISE magnetic chucks easily integrate with pallet changing and tombstone systems to user requirements.
  • facemilling
