Max Drill Press Guard
A spring-loaded plunger assembly securely locks the guard in a closed position whenever the guard is in the operating position. When released, the guard hinges up, allowing instant access. The guard is made from strong, injection, molded high impact polycarbonate which offers clear and safe vision through body and visor.
Drill Press Guard from Palmgren®
Designed to give full protection from quill to drill point, the smooth telescopic action of the Palmgren 2-1/8-inch Max Drill Press Guard collapses as the drill penetrates the workpiece.
It then returns to the extended position when the spindle is raised. A spring-loaded plunger assembly securely locks the guard in a closed position whenever the guard is in the operating position. When released, the guard hinges up, allowing instant access. The guard is made from strong, injection, molded high impact polycarbonate which offers clear and safe vision through body and visor.
The #9615025 Drill Press Guard from Palmgren® provides clear vision for safe operation, a rapid adjustment of drill length and fast access for cutting tool changes,
