MW Boring Head
MW Boring Head
BIG Kaiser Precision Tooling Inc. introduces a new small-diameter indexable rough boring solution for a range not previously available.
July 1, 2015
BIG Kaiser Precision Tooling Inc. introduces a new small-diameter indexable rough boring solution for a range not previously available. The new MW boring head permits small-hole rough boring in a diameter range of 16mm-21mm (630"-.827") and is ideal for semi-finish boring operations of workpieces with die cast holes.
Unlike other boring tools from BIG Kaiser, the new MW does not feature the modular KAISER KA/KAB connection. Built with a 20mm-dia. straight shank, the product performs best when paired with a milling chuck at fixed bore depths up to 4xd.
Efficient chip evacuation was a major consideration in the design of this tool. A spiral groove carved in to the body facilitates clean and quick chip removal with the help of coolant holes near the end of the groove. However, for blind-hole situations, an additional center-through coolant option was added to aid in chip evacuation for this tricky scenario. Simple stop screws makes choosing coolant preferences fast and easy.
The two opposing die-steel insert holders feature a precision serrated mounting system, providing a secure and rigid connection similar to the KAISER 319 SW series. The insert holders are conveniently marked with a scale for coarse setting, and the radial adjustment screw allows for fine-tuning thanks to its .008" pitch. Coated inserts are available for common materials like steels (including stainless), ferrous materials such as ductile and cast iron, as well as non-ferrous materials like aluminum.
  • boring head
    Single- or multiple-point precision tool used to bring an existing hole within dimensional tolerance. The head attaches to a standard toolholder and a mechanism permits fine adjust…
  • blind-hole
