MarkinBOX has released a new battery-operated, cordless part marker called Patmark. With a lithium-ion battery and charger, plus a software app that connects to your device via Wi-Fi, you can get a clean and clear mark without a cord.
You have the choice of either the Patmark 1533 or the Patmark Mini. The mini has a marking area of 15mm x 15mm and the 1533 has a marking area of 15mm x 33mm. Both devices have a solid-carbide pin that allows you to mark on materials up to 62 HRC. The easy-to-use software let’s you manipulate the size, depth and speed of your mark.
Marking on a variety of surfaces is easy with Patmark when you pair it with a quick- change fixture. These fixtures hold the marking device to the part using magnets, clamps, etc. Each fixture can be adjustable or fixed, depending on your marking needs, and gives you the ability to mark on round surfaces, end of parts and much more.
- fixture
fixture
