Reverse engineering application integrated into SOLIDWORKS
ReverseEngineering.com 2018 for SOLIDWORKS
ReverseEngineering.com 2018 for SOLIDWORKS is a reverse engineering application, fully integrated into SOLIDWORKS. Users can easily process point clouds, hard probe, and 3D laser scan directly in SOLIDWORKS. Tube measure and quick settings tooling dialog are two features new to the software.
“Engineers and product designers often struggle with the management of large 3D point clouds from 3D scanners. ReverseEngineering.com addresses those problems and provides specific tools to simplify workflow in real time,” said Braxton Carter, CEO, ReverseEngineering.com, HighRES Inc.
Quickly create a pipe or tube by sweeping a circle along an automatically generated path. Measure manifolds and add the bends in afterwards. Tube measure reduces time to model complex tubes and makes it more accurate than previous modeling methods.
Quick tool alignments have been consolidated with probe compensation. Hard probe direct to a drawing for inspection or dimensioning in real time.
With ReverseEngineering.com for SOLIDWORKS, users get support from an experienced team who have been supporting complex reverse engineering applications for over 21 years. ReverseEngineering.com supports multiple portable CMMs including Faro arms, MicroScribe, Romer arms, Kreon arms, BIG 3D Creator Optical Tracker, Faro Focus, and stand-alone point clouds.
New capabilities and enhancements include:
  • No wait time when processing gigabytes of point cloud scan data with Voxel thinning.
  • Automatic function generates profile curves through a point cloud allowing users to define and order equal number and spacing of points for parametric spline creation.
  • Enhanced lock plane simplifies your work flow, users can define point to plane snap tolerance capture with a hard probe or 3D scanner.
  • ReverseEngineering.com for SOLIDWORKS includes a standalone Integrated Point Cloud module that doesn’t require a SOLIDWORKS license to visualize points, hard probe or laser scan.
  • tolerance
    tolerance
