Safety Scale
Safety Scale
Danray Products LLC has just introduced its point-of-operation-opening safety scale that can be used to quickly check the point-of-operation opening for no safeguard required in accordance with OSHA 29 CFR 1910.217(c)(1)(ii) as well as applicable ANSI (American National Standards Institute) and CSA (Canadian Standards Association) machine safety standards.
August 13, 2013
Danray Products LLC has just introduced its point-of-operation-opening safety scale that can be used to quickly check the point-of-operation opening for no safeguard required in accordance with OSHA 29 CFR 1910.217(c)(1)(ii) as well as applicable ANSI (American National Standards Institute) and CSA (Canadian Standards Association) machine safety standards. It has a tapered design allowing it to be used in tight, obstructive areas.
The natural-aluminum scale is made out of durable, 0.090"-thick anodized aluminum, it has a 0.25"-diameter hole, and it has easy-to-read text and graphics that will not rub or scratch off. It is about the size of a credit card, which makes it convenient to carry and store.
