Tool precision depends directly on the production accuracy of the blanks used. There is a new addition to the market to create complex geometries with exact concentricity and dimensional accuracy: the cylindrical grinding machine ShapeSmart NP3+ from Rollomatic. Thanks to its modular structure, the machine can be easily adapted to any requirement and any budget.
The market demands ever greater flexibility, smaller batch sizes and increased efficiency in production. Manufacturers meet this demand with high-precision tools as an important performance factor. “But only those who enter the race with perfectly prepared blanks have any chance of a pole position in the formula one of precision heavy weights. High carbide quality is one factor, but only grinding on modern cylindrical grinding machines provides a great basis for high-precision milling tools, drilling tools or punching tools,” says Damien Wunderlin, head of marketing and sales at Rollomatic SA in Le Landeron, Switzerland. “We’ve therefore expanded one of our classics from an ergonomic and technical perspective with the result being the ShapeSmart NP3+, a powerful yet cost-effective cylindrical grinding machine.”
Available with three or four axes, the ShapeSmart NP3+ covers the usual requirements for a high-precision cylindrical grinding machine in the grinding range from 0.025 to 25.0 mm diameter. It works in accordance with the peel grinding principle and can perform roughing and finishing processes simultaneously. Rollomatic originally invented this technology and again facilitates never-before-achieved power in cylindrical grinding coupled with microprecision: this is how the workpiece guide system guarantees concentricity in the µm range. Even extreme lengths/diameters – e.g. for deep-hole drills or other special applications – are no problem for the NP3+ up to 400xD.
Users demand ultra-high precision. The Swiss company achieves this by continually optimizing the machine design and adapting the individual components in an ideal manner. In comparison to the popular predecessor model, the NP3, a few details have once again been enhanced. For example, Rollomatic uses a Fanuc panel with 15-inch display and integrated PC for the machine control. As Wunderlin comments: “Thanks to the new panel control and PC integrated, we were able to further enhance user-friendliness for the operator. In addition, the new panel control and PC makes it possible to integrate the in-process measuring gaging system so that the ShapeSmart NP3+ maintains even narrow tolerances as any potential deviations will be corrected automatically. This guarantees users optimum reproducibility and mirror finish surfaces in unattended operation – even for complex tool geometries.”
The pick-and-place tool loader enables everything from small to large batches to be ground unattended as it can manage up to 1,360 workpieces up to 300 mm long. With the Job Manager, 10 different tool profiles can be programmed and produced automatically. Thanks to the integrated flipper station, both ends of the workpiece can also be ground up to a length of 200 mm. The setting of the grinding wheel positions can be easily and automatically done with the gap control system. A 3D touch probe facilitates the localization of the tool end position that can be used for instance as second operation to peel grind undercuts on ground endmills. Indeed steps, cones and radii can be processed completely in one single chucking.
- cylindrical grinding
Grinding operation in which the workpiece is rotated around a fixed axis while the grinding wheel is fed into the outside surface in controlled relation to the axis of rotation. The workpiece is usually cylindrical, but it may be tapered or curvilinear in profile. See centerless grinding; grinding.
- grinding
- grinding machine
grinding machine
- grinding wheel
grinding wheel
