System 3R Delphin Zero Point Clamping System
The System 3R Delphin Zero Point system from GF Machining Solutions provides an affordable clamping system for use during heavy milling operations on a variety of machine tools. With the Delphin system, manufacturers can increase their overall productivity by streamlining setups and reducing machine idle time.
The System 3R Delphin system has been optimized to handle any type of machine tool including those with T-Slot or grid pattern tables, as well as machines with pallet changers. Its robust design features flexible references to allow quick implementation of existing fixtures and pallets, which provides economic and productivity advantages, according to the company. By minimizing the distance between the connection's reference surfaces and the workpiece to be machined, the mounting is more stable enabling operators to use the highest cutting rates.
The Delphin System offers the highest clamping force on the market at 60,000N per chuck face, with an accuracy of 5 microns in even the most challenging of conditions. It is available in pneumatic and hydraulic operating systems for a variety of machine tools to enable the machining of various sized workpieces, and for easy automation adaptation.
