TDM Cloud Line
TDM Cloud Line
TDM Systems, a subsidiary of Sandvik Machining Solutions, has introduced a cloud-based solution for Tool Data Management, TDM Cloud Line. A solution that enables manufacturers to easily access tool data wherever, whenever.
TDM Systems, a subsidiary of Sandvik Machining Solutions, has introduced a cloud-based solution for Tool Data Management, TDM Cloud Line. A solution that enables manufacturers to easily access tool data wherever, whenever. The official launch is slated for Dec. 1, 2017.
"The digital development process often still fails as a result of data gaps and media breaks in the tool area," explains Peter Schneck, CEO of TDM Systems. "The quality and availability of tool data is crucial to the success of metalworking companies. Our cloud-based solution marks the start of the digital transformation for users."
TDM Cloud Line is based on TDM 2017 Global Line, the fully modernized tool data management solution launched earlier in 2017. The key advantage of TDM Cloud Line is that users can download and manage data from thousands of tools without having to purchase them. It can test alternative tools during the product design process and select the optimum tool for the specific design. At present, users have only data from tool manufacturers available to them, which can vary both in quality and depth. Data from the TDM cloud is available anywhere and is ready for immediate usage in the virtual cutting process.
"Sandvik is assuming a leading role in the digital transformation of tooling with the introduction of TDM Cloud Line," says Hugo Nordell, director digital solutions, Sandvik Machining Solutions. "The TDM Cloud Line solution enables customers to accelerate their engineering process, simulate the use of various tools and securely plan production on the basis of comprehensive, precise tool data."
TDM Cloud Line offers numerous advantages: Easy set-up of your own tool database; optimally prepared, tested and comprehensive tool data for immediate, intuitive use; provisioning of correct CAM data; manufacturer-independent tool assembly; statistical evaluation; clearly structured and individually configurable user interface and cloud-based solution available at any time in any location.
