![TechniDrill 2.00-30-48 TechniDrill Gundrilling Machine for Aerospace Applications](/sites/default/files/styles/product_image/public/product_images/TechniDrill%20Machine%20Photo_0.png?itok=aOhyAAAT)
The TechniDrill 2.00-30-48 is a gundrilling machine used to manufacture airplane aileron actuation cylinders. The actuation cylinder starts as a solid bar. The gundrilling machine drills the large primary hole in a single pass, without the need for a pilot hole. Secondary processes are then utilized to finish the cylinder.
The TechniDrill 2.00-30-48 has a gundrilling diameter capacity of 2.0 inches (50.8 mm) and a maximum gundrilling depth of 48 inches (1219 mm). It features a 30 horsepower AC spindle motor and two-speed gearbox to provide versatile gundrilling performance. The workpiece is counter-rotated during gundrilling via pneumatically operated 3-jaw chucks, which increases the accuracy of the drilled hole.
- gundrilling
gundrilling
Drilling process using a self-guiding tool to produce deep, precise holes. High-pressure coolant is fed to the cutting area, usually through the gundrill’s shank.
