Weiler Abrasives has expanded its offering of small-diameter cutting and snagging wheels for high-speed die grinders to include Tiger AO, Tiger Zirc and Tiger Ceramic. These 2- to 4-inch diameter wheels are designed for long life and fast cutting and join the Wolverine value wheels already offered in this category.
The 38 item-expansion provides end users in the metal fabrication and ship building industry with increasing levels of cutting performance to meet their needs. Weiler Abrasives will offer the Tiger wheels with 1/4- and 3/8-inch arbor hole sizes.
Weiler’s Tiger AO cutting wheels feature an aluminum oxide grain and provide even, sharp, clean cuts along with a hard bond to extend wheel life when cutting steel. Like the Wolverine wheels, Tiger AO wheels are available in thicknesses of 0.035, 1/16, 1/8 and 1/4 inch.
Weiler Abrasives is offering its high-performance Tiger Zirc cutting wheels in 0.035-inch thickness. These wheels feature sharp, aggressive zirconia alumina grains that retain a high cut rate throughout the life of the wheel, making them an ideal choice for cutting steels, including structural and cast iron.
For maximum cutting performance, even on stainless steel and hard-to-grind metals, the Tiger Ceramic cutting wheels provide superior life. The self-sharpening grains reduce discoloration by cutting at lower temperatures with less friction and require less effort to use, minimizing operator fatigue. The wheels are available in 1/16-inch thickness.
Weiler Abrasives’ small-diameter wheel offering also includes Type 1 Tiger AO and Wolverine AO snagging wheels for die grinders, as well as Type 27 Tiger AO wheels. This expansion builds on Weiler Abrasives’ offering for die grinders, which includes Tiger Bobcat mini flap discs, flap wheels, blending discs and wire end brushes.
- aluminum oxide
aluminum oxide
Aluminum oxide, also known as corundum, is used in grinding wheels. The chemical formula is Al2O3. Aluminum oxide is the base for ceramics, which are used in cutting tools for high-speed machining with light chip removal. Aluminum oxide is widely used as coating material applied to carbide substrates by chemical vapor deposition. Coated carbide inserts with Al2O3 layers withstand high cutting speeds, as well as abrasive and crater wear.
- arbor
arbor
- fatigue
fatigue
