UNi5X-400 5-Axis Vertical Milling Center
The UNi5X 5-axis high-speed vertical machining center from Chevalier Machinery Inc. reportedly offers high accuracy, enhanced productivity, low manpower and high profitability.
May 8, 2018
A one piece inverted Y-shape column design offers enhanced rigidity and stability. The pretensioned Class C3 ball screws are used in all three axis. All serv motors are directly coupled to ball screws, increasing movement sensitivity while dramatically reducing backlash.
A large-diameter BBT spindle design uses four-piece of P4 Class and high-precision angular-contact ball bearings to increase spindle rigidity and loading capability and to maintain high accuracy during high-speed machining.
  • machining center
