V760EX Vertical Lathe
Okuma has introduced its new V760EX vertical lathe, an update to the popular V60R model.
Okuma has introduced its new V760EX vertical lathe, an update to the popular V60R model. This new version provides a larger work envelope in the same footprint, allowing for an additional 110mm in workpiece height and an additional 150mm maximum turning diameter. It provides stable, high-precision cutting in a small footprint and is an excellent platform for machining thin and odd-shaped work pieces, and is well suited for the oil and gas and aerospace industries.
The V760EX vertical lathe has powerful cutting capabilities, a class leading working range, and excellent ergonomics. The box way system and rock solid base and column provide a highly dependable, highly rigid structure. The headstock has flange construction including precision, hand-scraped mounting surfaces. This minimizes the effects of thermal deformation and vibration, ensuring stable, accurate cutting.
This machine's ergonomic design includes easy access to the chuck and a front-skirt operation panel, providing convenience for up-close jobs.
