Variable-Speed Drill Press
Easily adaptable, Palmgren's 20-inch, variable-speed drill press allows the operator to select the best rpm for the tool and material without stopping the job. The ergonomic side-mounted hand wheel instantly adjusts the speeds.
Easily adaptable, Palmgren's 20-inch, variable-speed drill press allows the operator to select the best rpm for the tool and material without stopping the job. The ergonomic side-mounted hand wheel instantly adjusts the speeds. Then the rpm reading appears on the front face of the machine. The drill press features a heavy-duty drill head with the bearing surfaces bored simultaneously for exact alignment.
