VB-1400/VB-1600/VB-2000 Vertical Machining Center
VB-1400/VB-1600/VB-2000 Vertical toolchanger. See automatic toolchanger." title="CNC machine tool capable of drilling, reaming, tapping, milling and boring. Normally comes with an automatic toolchanger. See automatic toolchanger." aria-label="Glossary: machining center">Machining Center
The VB-1400/VB-1600/VB-2000 vertical machining center from Cubic Machinery has a 10,000-rpm spindle, 24-tool automatic toolchanger and spindle oil cooler.
The VB-1400/VB-1600/VB-2000 vertical toolchanger. See automatic toolchanger." title="CNC machine tool capable of drilling, reaming, tapping, milling and boring. Normally comes with an automatic toolchanger. See automatic toolchanger." aria-label="Glossary: machining center">machining center from Cubic Machinery has a 10,000-rpm spindle, 24-tool automatic toolchanger and spindle oil cooler.
The high-speed spindle is a true cartridge type unit supported by P4 precision class high speed bearings, which are permanently grease lubricated to eliminate heat buildup. The spindle is driven by a high-torque FANUC spindle motor. Power is transferred through a heavy-duty, cogged drive belt, eliminating slippage, promoting thermal stability and minimizing vibration.
The spindle coolant system refrigerates and circulates cooling oil to maintain a constant temperature for high accuracy across different cutting conditions and ambient temperature.
The VMC features:
- Four boxways on Y-axis to distribute heavy loads evenly
- Turcite-B coating on all slideway surfaces
- P4 precision class spindle bearings
- C3 double nut, precision ground, large diameter ball screws on all three axes
- Screw-type conveyor makes chip cleanup a breeze
- Industry standard FANUC 0iM control
- Spindle oil cooler to maintain constant spindle temperature
- 100 percent laser-tested positioning accuracy
- ISO 9001/2000 certified quality assurance
