DCM Tech’s Punch and Die Grinder is a turnkey package with auto-feed control, self-dressing CBN abrasives, through spindle coolant and universal fixturing that accepts Amada, Trumpf, Salvagnini, Finnpower, Weideman, Whitney, and other style tooling. Sharpen large station dies and rooftop/shear angle tooling up to 10 degrees with the standard fixturing package. Typical grind time is less than 5 minutes.
For more information from DCM Tech, click here.
- coolant
- cubic boron nitride ( CBN)
