Let’s talk about machining soft jaws for use on a lathe. Figure 1 shows two sets of soft jaws. The jaws on the left are made from 1.25" x 2.5" 6061 aluminum flat. These jaws were made for holding round aluminum parts.
The jaws on the right are made from 1.125" x 1.75" 1018 steel flat. They were made to hold a rectangular feature on a steel part. Both sets of jaws are made for an 8" three-jaw scroll chuck with American standard tongue-and-groove mounting. The jaw in the middle shows this mount. The geometry for this mount is in the Machinery Handbook and other places.
I make my own jaws, but sets of jaw blanks ready to be bolted to a chuck are available from tool suppliers. For round parts this is a time-saver. Just bolt the jaws to a chuck, set the diameter of the jaws, and machine the jaws for the part to be held. No milling operations are necessary. When machining the jaws for the part to be held always tighten the chuck in the direction of the clamping force. Use a ring or piece of bar and clamp against it. Details matter.
Figure 2 shows the part for which the steel jaws in Figure 1 were made. It is a spindle for a measuring machine. The finished part is on the left and the blank for the part is on the right. The blank is made on a milling machine from 0.75" x 1" 1018 steel flat. A 0.437" through hole is drilled and reamed and the 1" dimension is cut to 0.75" to shorten the lathe operation time. This part could be held on the lathe with a four-jaw independent chuck, but having a set of jaws made for the part on a good scroll chuck makes for better accuracy and repeatability, and saves time per part. Taking care when making the jaws is important.
Figure 3 shows the part in its jaws as it would be on a lathe. To make these jaws, three pieces of 1018 steel were clamped in a milling vice, and the tongue-and-groove mount machined. Then the three-jaw blanks were bolted to an 8" scroll chuck on an index with the tongue-and-groove mount, and the rectangular feature for holding the spindle was made. See my last article for a picture of the index. The finished jaws then go on the lathe, and the lathe is ready to make money.
For this part, the centerline of the spindle and the 0.437" through hole must intersect within 0.003", and this setup hits that mark with ease. I have used this set of jaws to make hundreds of these spindles over the years and I don’t think that my customer ever rejected one. An accurate tool is a good tool. An inaccurate tool is an expensive tool.
- chuck
chuck
- flat ( screw flat)
flat ( screw flat)
- lathe
lathe
- milling machine ( mill)
