Turning to CNC
Author Michael Deren
January 01, 2001 - 11:00am
A look at the various types of CNC lathes available to shops contemplating stepping up from a manual machine. The pros and cons of the following lathes are discussed: combination, cutoff, slant-bed, twin-spindle and turn/mill. The author also touches on available options.
Read the Full Article
  • cutoff
    cutoff
    Step that prepares a slug, blank or other workpiece for machining or other processing by separating it from the original stock. Performed on lathes, chucking machines, automatic screw machines and other turning machines. Also performed on milling machines, machining centers with slitting saws and sawing machines with cold (circular) saws, hacksaws, bandsaws or abrasive cutoff saws. See saw, sawing machine; turning.
Author
Machinist's Corner Columnist
Michael Deren is a manufacturing engineer/project manager and a regular CTE contributor. He can be reached via e-mail at mderen1@wi.rr.com.
