Dormer Pramet unveils new products for 2025
March 07, 2025 - 08:30am
Dormer Pramets says its new indexable milling and turning tools 'push boundaries.'
Dormer Pramet is expanding its portfolio of indexable tools with the launch of high-performance turning and milling solutions.
Designed to maximize productivity, these tools combine enhanced precision, durability, and efficiency, empowering manufacturers to go beyond limits in their operations, according to the company.
The new Dormer Pramet tools feature advanced materials, innovative designs, and next-generation coatings. The company adds that they deliver the reliability and efficiency needed to tackle today’s toughest machining challenges.
New turning products
The latest additions to the Dormer Pramet turning range include:
  • T5415 CVD grade: Ideal for turning nodular cast iron and ISO H group materials, T5415 offers outstanding durability in interrupted cuts and improved wear detection, ensuring reliability in high-performance turning operations.
  • KM chipbreaker: Designed for ISO K group materials, the KM chipbreaker features a wide T-land and positive rake angle for smoother, more consistent cuts. When paired with the T5415 grade, it provides excellent stability, process security, and performance in medium turning applications.
  • GL. S-PM inserts: Designed for deep parting-off and grooving of non-ferrous materials and titanium-based superalloys, these inserts deliver superior wear resistance and extended tool life, ensuring reliable performance even in continuous or slightly interrupted cuts.
New milling products
Dormer Pramet milling innovations for 2025 include:
  • STD series for shoulder milling: Featuring triangular inserts and four adaptable cutters, the versatile STD series handles light, medium, rough, and aluminum machining with depths of cut up to 11 mm, offering cost-effective and flexible solutions.
  • SRN series for copy milling: This economical series includes double-sided round inserts with eight cutting edges, maximizing material removal rates and reducing costs by up to 20%. SRN provides smooth cutting and enhanced stability for high-performance applications in aerospace, energy, and other industries.
“These offerings represent not only our latest technological advancements but also the unified strength of Dormer Pramet as a master brand”, said Eduardo Martin, President of Dormer Pramet. “This marks the beginning of a new era where our combined expertise delivers innovative, sustainable, and customer-focused solutions.”
  • chemical vapor deposition ( CVD)
  • chipbreaker
    chipbreaker
    Groove or other tool geometry that breaks chips into small fragments as they come off the workpiece. Designed to prevent chips from becoming so long that they are difficult to control, catch in turning parts and cause safety problems.
  • gang cutting ( milling)
  • grooving
    grooving
  • milling
  • rake
    rake
  • superalloys
    superalloys
  • turning
  • wear resistance
    wear resistance
