![](/sites/default/files/styles/headline_teaser/public/headline_teaser_images/cnc-broach-logo.png?itok=BtTRJX1Q)
John Gardner, a founding partner of Razorform Tools, has started CNC Broach Tool LLC to provide a line of off-the-shelf, inserted keyway broach tools for CNC lathes and mills, Gardner announced in a news release Jan. 20. CNC Broach Tool will continue to sell direct to provide CNC keyway broaching technical support and cut costs for end-users.
Located in Marina del Rey, Calif., CNC Broach Tool has patented a unique design that is said to allow manufacturers and job shops to make complete parts on a CNC machine, and remove secondary operations done on a keyseater, EDM or broaching machine. That capability is said to provide another step toward a lean operation while reducing machine downtime and offering significant savings in shop time.
Click here for more about the company's keyway broaching tools.
Click here to visit the CNC Broach Tool website.
- broach
broach
Tapered tool, with a series of teeth of increasing length, that is pushed or pulled into a workpiece, successively removing small amounts of metal to enlarge a hole, slot or other opening to final size.
- broaching
broaching
Operation in which a cutter progressively enlarges a slot or hole or shapes a workpiece exterior. Low teeth start the cut, intermediate teeth remove the majority of the material and high teeth finish the task. Broaching can be a one-step operation, as opposed to milling and slotting, which require repeated passes. Typically, however, broaching also involves multiple passes.
- broaching machine
broaching machine
Machine designed specifically to run broaching tools. It is typically designated by operating characteristics (pull, push, rotary, continuous, blind-spline), type of power used (hydraulic, mechanical) and tonnage ratings. Broaching is also performed on arbor presses (manual and powered).
