5-Face Bridgeport Vertical Machining Center
5-Face Bridgeport Vertical toolchanger. See automatic toolchanger." title="CNC machine tool capable of drilling, reaming, tapping, milling and boring. Normally comes with an automatic toolchanger. See automatic toolchanger." aria-label="Glossary: machining center">Machining Center
Hardinge Inc. announces the release of two Bridgeport 5-Face (4+1) Vertical Machining Centers: the GX 250 5F and GXR 320 5F.
April 13, 2013
Hardinge Inc. announces the release of two Bridgeport 5-Face (4+1) Vertical Machining Centers: the GX 250 5F and GXR 320 5F. These 4+1 axis vertical machining centers are high quality machine tools designed to achieve maximum capacity and performance in the job shop, OEM, aerospace, medical, electronic, defense, automotive and power generation industries, as well as many other manufacturing sectors.
Two machine sizes are available and come standard with a sophisticated, yet user-friendly, FANUC 0i-D control for 4+1 machining. 4+1 refers to the use of four simultaneous axes plus one axis that is used for positioning only. 4+1 or 5-face machining is a step up from 3-axis machining where just 1 or 2 sides of the part are machined per setup. 4+1 machining allows the part to be machined on 5 faces in one single set up. The part remains in one fixture instead of being moved from one fixture or vise to another, drastically reducing setup time while improving accuracy.
The GX 250 5F (4+1) with travels of 11.8" x 15.6" x 16.9" (X,Y,Z) provides fast rapid traverse of 1181 inches per minute on X, Y and Z axes and features a powerful 20hp, 15,000-rpm direct-drive spindle motor with 70.4 ft-lbs of torque and a 30-tool swing-arm automatic tool changer. The larger GXR 320 5F (4+1) with travels of 20" x 24" x 20" (X,Y,Z) provides very fast rapid traverse of 1693 inches per minute on X and Y axes and 1417 inches per minute on the Z axis. The machine features a powerful 25hp, 12,000-rpm direct-drive spindle with 86.3 ft-lbs of torque and a 48-tool swing-arm toolchanger/" data-glossary-id="142091" data-glossary-teaser="Mechanism typically included in a machining center that, on the appropriate command, removes one cutting tool from the spindle nose and replaces it with another. The changer restor…" title="Mechanism typically included in a machining center that, on the appropriate command, removes one cutting tool from the spindle nose and replaces it with another. The changer restor…" aria-label="Glossary: automatic toolchanger">automatic toolchanger.
Bridgeport 5-Face (4+1) Machining Centers feature an integrated 5-axis robust rotary table supported by large bearings to allow heavy horizontal and vertical cutting loads with smooth and accurate rotation at all times. Bridgeport incorporates heavy-duty linear guideways and oversized double-nut ballscrews that are pre-tensioned to provide superior accuracy and repeatability. The linear way modules consist of slide members (guide trucks) and linear rails to provide a large load rating, stable accuracy, high rigidity and low friction. The wide spacing between all axes rails provides optimum stiffness for the overall machine structure. Oversized 45mm (1.77") ballscrews are featured in the GXR 320 5F, while 32mm (1.26") ballscrews are incorporated in the GX 250 5F. All of these robust features are designed into a small cost-effective footprint.
Bridgeport 5-Face (4+1) Machining Centers have a work envelope to machine small to medium parts. Machines with larger work envelopes use a larger rotary table, increasing the size of the machine, increasing the overall cost. Bridgeport offers a smaller footprint machine for 5-face machining that is ideal for the medical and dental market and that complements the automotive, aerospace and other industries as well.
Both machines come packed with standard features including a BIG-PLUS spindle, oil chiller, chip conveyor, coolant flush system, preparation for through spindle coolant (with rotary union), coolant wash down gun, tri-color stack light and many standard control features.
"These new Bridgeport 5-Face (4+1) Machining Centers offer a high degree of sophistication and functionality in a small footprint at an attractive price," states Andy McNamara, Director of Sales and Marketing, North America. "Like all Bridgeport machining centers, these machines reflect Hardinge's commitment to quality and performance without compromise."
  • automatic toolchanger
  • machining center
  • rapid traverse
  • work envelope
  • toolchanger
