Mitutoyo announces the ABSOLUTE AT1100, the latest generation of assembly-type linear scales that incorporate Mitutoyo’s electromagnetic induction technology, which provides resistance against contaminants such as cutting fluids, oil and water. The innovative shape and location of the detector track in the aluminum frame provides a highly effective defense against the contamination of the scale and sensor, even in harsh environments.
The sensor-to-scale air gap is approximately 0.4 mm, about four times as wide as that of conventional optical or electromagnetic induction systems, thereby providing additional protection against dust or oil contamination.
ABS AT1100 Linear Scales are available up to an effective range of 3,040 mm and are compatible with FANUC Corp.’s serial interface and Mitsubishi Electric Corp.’s high-speed serial interface.
ABS AT1100 series scales are a special order item.
