Cartridge Arbor with Interior Swing Clamps
The Positrol cartridge arbor with interior swing clamps is designed to increase part rigidity during machining operations without interfering with tool paths.
July 8, 2016
This innovative design allows the Positrol cartridge arbor to locate on the ID while the interior swing clamps pull the part back. These arbors are primarily engineered to simplify fixture designs used in the automotive industry where high production, low cost manufacturing is deemed critical with today's economy.
An example of a part suitable for this workholding application could be a steering knuckle. Parts are gripped and held securely to withstand the cutting forces generated in production machining. The added rigidity of the workholding allows for a boost in speeds and feeds to increase overall throughput.
